The Bimmubishi is approaching her final hour. The engine mounts are in and I have a couple of questions at this juncture.
1) what's the largest rear wheel/tire combo I can run? I was thinking of 15 inch rears (diameter) and 8 inches wide with the correct 20mm offset and a 235 tire. If I roll the fenders will it work?
2) I fabricated my motor mounts and they work great, the motor's in and supported on it's own now. The question i had about the rubber mounts is, that if they're bent a little, as in distorted out of their normal position will they fail quickly? If the answer's yes, is there a good, non fluid filled one that I should look into?
Please let me know.
Thanks for all the help.
Alex
Mitsu powered 318 coming soon.
Please let me know.
Alex
