V.Light Steering and Bad Economy
24
Athens,Greece.
Well,lately my steering has lost much of the feeling it used to have and to be more precise it s now much lighter in straight line motion...
Any ideas ?!? What should I check out ?!? Other than that the car feels normal (xept that it still has a lousy economy or around 23mpg or 12lt/100km).
Thanks for any help...
BTW,the car is an E30 318i (non cat,pre'88 model).
A3TeRnuS.213
174
Oregon
Hello.
I have owned two pre'88 318i's. I have a 1984 and 1985. They are parts cars now, bought them with high miles and drove them as long as a could... I paid like $300 for the last one.
I got way better gas milease then 23 mpg. I would get an average of about 28mpg, I live out in the country so I do highway and city driving. I took the car to canada once, and on the way back with the radiator half plugged up and the heater on high the whole way it got 35 miles the the gallon. However this was not a stock 318i.
I had bigger injectors, venom ones to be exact. I had a pacesetter header and the cat converter removed. I picked out a stupid muffler in summit and thought it would work but when I got it I could see through it. It was loud but had lots of top end power. I had a K&N filter in the factory air box. I did have redline MTL in the tranny and redline 75w-90 in the differential. I bought this car for $300 and started putting the hop-up parts on it.
Check your timing. The fuel injection on this car does not control the timing like other bmw's. Make sure to have good plug wires, cap and rotor.... I used only bosch. Make sure to run fuel injector cleaner every few tanks. Back to timing, I did not set mine with a light since its a royal pain in the a$$. You have to look through a hole on the bell-housing with the timing light and see a line mark on the flywheel... of course wires and coolant lines are in the way. I set my timing by ear. I used 89 octane fuel. I would keep bumping the timing up a couple degrees until it started pinging slightly below 2000 rpm. Its to far advanced if the starter cranks over hard and slow. I know this is a little hot on the timing but those M10's always liked running from 2,000 rpm and up. Anything lower and it was lugging the engine. Its better to rev and engine then lug it.
One last thing, I would adjust the valves in my cars twice a year. My cylinder heads needed rebuilt though, so the valves required frequent adjustment. Now factory spec if I remember right is something like .010 or .2mm? . I read somewhere that the people who use the M10 engine in race cars run there intake valves at .006 cold and .007 on the exhaust. I thought those specs were a little tight so I ran .007 intake and .008 exhaust. Having the valves adjusted to these specs makes the engine run so good and smooth. You might hear some valve tick but all rockers should be about the same. You will hear if you got one to loose.
These are just my humble suggestions. This is what I did with my two 318i's. Some people will probably disagree with some of the things I did but the cars lasted me. Never left me stranded, got good mileage, and were a balst to drive. I now have a 325 with an eta 2.7 and glad I have it... the 6's power is just so nice. I cant wait to build a 3.0 m20 to stuff into the 325.
Later
I still have them both and will eventually build a race car with all the parts. I even got a '78 320i 2.0 liter engine to build up and put into the E30.
174
Oregon
Forgot the steering issue.... that has me baffled. The only problem I had with the steering was on the '84, the rack was starting to leak fluid. Maybe see if you can find a nice M3 rack to put into it if you have to replace the rack, be nice upgrade if you have to go that route.
24
Athens,Greece.
Well,the whell is not power supported,so the pump is out of the question...
Hmmm...ldzpstnr you somehow confused me a bit...
I ll use some kind of injector cleaner and then i ll adjust my valves then see what happens.
Thanx for the info !
A3TeRnuS
24
Athens,Greece.
Someone suggested that i should check out/change the "rubber coupling between the two steering column uni joints".Can a Haynes manual help me do it myself or the dealer should do this for me ?!? Is it expensive ?
Thanx for any info...
A3TeRnuS
368
Ventura CA
Two things - First, Bentley manual is better than Haynes. Haynes manual has been declared by many to be inadequate in many areas. I've never used one to try to fix anything but I've done some fairly impressive stuff with the Bentley.
Second, changing that coupling doesn't seem that involved. It seems it is only two bolts, one at each end, that hold it in place. Bentley does say if the rubber coupling or either of the universal joints is worn or defective, the entire universal joint shaft should be replaced. Not mandatory but should.
I haven't heard of anyone on this board ever replacing it or even checking it out. Of course, I haven't been around that long, only a year or so. You might start a new thread asking if anyone ever had an issue with the universal joint shaft. It would be interesting to see if anyone responds.
Good luck.
Steve
Ben
576
NY
some of the common areas for loose steering are tie rods and ball joints. you can check the tie rods by jacking the front of the car up and moving the wheel from side to side. if that is the area where the problem is, it will have some play in it. to check the ball joints, leave the car jacked up and pull the bottom of the wheel out and push the top in. if the ball joints are bad, there will also be play.
880
Pittsburgh, PA
a3ternus, when i replaced my steering rack, connecting the new rack to the joint was by far the most difficult part of the task. I am looking into replacing the joint because i have a decent amount of play in my steering as well, but that probably won't happen for a few weeks from now.
Anyway, I seriously dread putting the new joint back in..... anyone have any tips for getting it onto the rack easier?
