Since I bought my 328i it has been gradually getting flatter performance wise but the engine seems to run smoothly enough etc. I keep the engine well and fully serviced but the performance never got better. So I eventually got the thing hooked upto the engine diagnostics and worked through the list of faults.
1. Crackshaft Sensor - VANOS
I replaced the crankshaft sensor, went back on diagnostics and all was well and the car ran much better but still lacked somewhat in the performance department. Then a month later it went back on the diagnostics and it came up with;
2. Oxygen sensors BANK 1 & BANK 2 - VANOS
I put on a new catalytic converter and 2 new NGK/NTK 02 sensors and then hooked it upto the diagnostics again. It came up with no faults but the car didn't run much differently at all despite one of the old 02 sensors being pretty much snapped in half so a new set should have made some difference!
So I ran the car for a few more weeks and started to get the odd jerk whilst driving and then hooked it back upto the diagnostics and its showing the VANOS as being faulty. So can anyone tell me exactly what job the VANOS does? and what causes the VANOS to become faulty (these are supposed to be robust units to my understanding)?
Do you think that the engine will pick up better once the VANOS is replaced as the acceleration stays flat as the revs rise at the moment and my fuel consumption is a bit on the high side too? I am desperate to get the engine accelerating the way it is supposed to
