By side panels you mean door panels I assume?
There are two screws behind the trim that runs from the inner door handle (to open door) to the edge of the door panel. It just pops off. start at the end furthest away from the handle (edge of the door) and gently pry. It is held on with four clips.
There is another screw behind the power mirror switch. Take a tiny screwdriver or whatever and pry the switch out on both ends, it is just popped in. Be careful not to damage the door panel doing it.
There are two final screws under the armrest on the door. Just pop off the little plastic screwhole covers and there they are.
After removing all the screws (they are torx BTW), pry the door panel gently out at the bottom until the plastic clips start to pop out. Then just work your way around the door panel until you get to the top. Yank it out from the front first (under the small speaker at the top by the side mirror), then along the rest of the top. Unhook everything and you are done.
Oh yea, one last thing. There are tiny felt washers on each of the plastic clips that hold the door panel on. DON'T LOSE THEM. They tend to fall off when you take the door panel off, and if you don't put them on, you can get squeaks from the door panel.
