water spots
Are you saying that you can't get them off with repeated washings, or each time you wash it you get new water spots? If you are just trying to prevent new water spots after each washing, use a chamois or California Water Blade to remove the water before it air dries.
rjp325i
511
Henderson, NV
A clay bar should work on the paint and then keep a good coat of wax on it. Try not to let the water dry before getting it off. To make this a little easier, after washing get the car into the shade. If you can, wash the car in the shade also and rinse frequently. We have hard water here in the Las Vegas area and water spots are always a consideration. As for water spots on the glass, try using white vinegar to remove them. Put some in an old "Windex" bottle and spray it on just as you would a regular glass cleaner. You will problably have to do the glass a few times if the spots are baked on. The vinegar works on glass shower doors as well.
480
Sydney, Australia
Having a black car I feel your pain. Dry your car with a chamois and then immediately go over that newly dried area with a micro-fibre (clean!!) cloth. Leaves your car looking incredibly good and you don't get any water spots because there are no streaks of water after you use the second cloth. Also washing in the shade is excellent if you can.
