What tires will fit?
BOnTrak
9
Cincinnati
Has anyone had experience fitting an 18-inch wheel w/wider than 225mm tires on the front of an e46 330i? What tire, what size, and what offset?
I've got +42 offset 8.5-in wheels in the front, and I'm interested in going to a 245/35, but not sure if it'll clear...
Also, the rear wheel is a 9.0 rim with +45 offset; if I go to same size front/rear, will I be able to swap front and rear tires and rims, or is it advisable to only run the wider rims in back?
-b.
