Do you hear the pump run when you try it? If so, then the fuse and pump are OK.
My Volvo always clogged the washer jets. I used a VERY small wire, like 28 gauge, to insert into the jets and clean them out. Just be careful that you don't break it off inside the jet. Haven't had this problem on the bimmers.
