Xenon lights flicker
plyubich
22
b
Hi Guys,
I just replaced my regular headlights with Xenon lights. They work, but from time to time, especially when I drive at higher speeds, they start to flicker. I noticed that this happens when I press on the gas pedal harder, and they flicker when the gas pedal is released. The same happens when the car is stopped. I purposely press on the gas pedal and notice that the lights flicker when the rpms start to go down. Also from time to time, the left light goes out, but when I restart the car, everything works fine, the left light turns on and they don't flicker.
I've herd that if the car came with the non-xenon lights and those lights are replaced with xenon lights, either the light switch needs to be reprogrammed or changed. But if this is done, then the high beams don't work, instead the high beams are activated by the xenon's elevating up.
Any help would be appreciated.
Thanks in advance.
