I have an appointment on May10 (BMW loaner reserved) at Fields BMW, Winter Park, FL (where I bought the car) to fix the following:
1. Velvety trim around the door is separating from the rubber trim all over the place, both passenger and driver sides. Kinda hangs down and wants to choke ya. They say this is common in FL and TX and they replace the entire part, both sides, including the rubber trim it's attached to that contains the anti-close-on-your-fingers sensors. They admit this will fall off again, but they give a two year warranty even if you are near or out of warranty. I can picture myself pulling it off as I near the end of my warranty even if it isn't falling off on it's own.
2. The clips broke on my sunshade, so if you try to open the sunroof all the way, it makes a nasty cracking sound like more stuff is breaking in there. A small black piece fell down in my lap twice. I remember posts describing this as "common".
3. My right lower passenger side speaker area rattles with low freq notes at a little volume. Has done this since day two. This is third attempt to fix it.
4. My radio reception is mediocre in FM and almost non-existent in AM band. They claim my tint can cause this even though it is non-metallic. I have pre-arranged for them to pay for re-installation if they take it off and the problem persists. I am pretty confident the tint is not causing this. This is second attempt to fix this one.
I got the loaner because I WILL NOT give it back until I am satisfied they have fixed all the issues. I am a bit angry at the low quality in these areas for a $45K car.
Whew. Thanks for the vent pipe......
![Mad [mad] [mad]](/images/smilies/mad.png)
