Engine oil for E46 325i 2002
112
Monterey, CA
I use Mobil 1 10W-30 Fully Synthtic Motor Oil. Works well for me since I drive my car on a daily basis commuting or cruising with friends. Good too for high preformance too at hte same time. Hope that helps.
58
Atlanta GA
Does anyone use the BMW synthetic oil which they say is good for 15,000 miles !!!!
That is what BMW dealer said and they charge $83 for oil and filter
Bmw 325i 7803
1,853
williamwoon said:
Hi guy s
what engine oil do you use for your E46 325i 2002 BMW? any recommendation.. i know BMW has official oil by Castrol ..
thanks
william
The correct oil for that engine is 5W 30 castrol or mobil 1 syntec.
The BMW oil which "lasts for 15k" at the dealer is actually castrol syntec 5w 30 and it comes out of a 40 gallon drum, hardly anything special.
Arkansas
reset oil display
Do you know how to reset the oil display back to 5000 miles after you change your own oil?
58
Atlanta GA
I need to know how to reset it also....as I changed my oil yesterday at a mechanic round the corner but i never asked him to reset it....he did not see to know
33
Melbourne
yeah i would also like to know how to reset the counter.. i just had an oil service not to long ago. and also where do you see the actual counter to measure the oil left till the next service.
any help that would be great
53
Utah
I changed my oil today. I used 0W 40 Mobil 1 all Synth.
This is how you reset the oil gauge (from my330.com):
A. Model Year 1999 to Mid-2000: You should have the older round 20-pin DLC connector under your hood behind the battery terminal, you need to use a small length of wire to connect (short) pins 7 and 19 for 3-5 seconds with the ignition key in position 1 (Accessory).
B. After Mid-2000: You should not have the 20-pin DLC connector. You only need to hold the left odometer reset button while turning the key to position 1 (Accessory). Keep holding the button for 5 or so seconds until any of the following shows in the display: OIL SERVICE or INSPECTION with RESET or RE. Release the button and press it again for another 5 or so seconds until RESET or RE flash. While the display flashes, press the button one more time briefly. If done correctly, END SIA should show up for a few seconds. All done.
MGW-Fla
3
Jacksonville Florida
Thanks for the info on resetting the oil service reminder! I've been looking for that info. I use a synthetic 20w50 here in the heat of Florida. Try to use at least a 10w40 in all my cars.
Sounbwoy
16
Raleigh, NC
I realize it's your $$, but 20W oil for Florida is probably overkill. Why not just make it consistent for all your cars and use 10W?
11
Florida
#16
I also live in Florida, but I still put the recommended oil in my car: Castrol Syntec 5W 30. I buy it from Wal-Mart (comes in a handy 5 quart jug). AutoZone is where I get my oil filter (yes, they come with rubber gasket/ring and the drain plug metal seal). Bavarian Autosport provided the reset tool...well worth the money BTW.
#17
There is some discussion by BMW groupies that Mobil1 5w-30 tests thinner in lab evaluations than Castrol 5w-30, and has been the cause of VANOS noise due to lower oil pressure. I personally found this out through first hand experience with my '94 E36.
If you go to Mobil1, it is better to use 10w-30 or 10w-40 Mobil1 where 5w-30 Castrol is normally used, especially in warm climates, high mileage engines, or racing/autocross.
Also, if you check the Mobil1 Web site, you will find that they recommend 10w-40 for BMW E46 engines, NOT 5w-30.
11
Florida
#18
As a matter of fact, I started using Castrol Syntec in my VW too, instead of Mobil 1. The Castrol is a bit cheaper, seems to offer better protection (according to some studies I've seen), and having one type of oil in the garage is easier too. [:D]
1,035
Maryland
#19
Kirby, when I switched to synthetic I used mobil1 5w30 and there was a strange as hec metal to metal sounding noise that happened once; never again. This leads me to wonder whether next time I should switch to 10w30; I never did; I keep running 5w30. However, its starting to get high mileage (+130K), and it's warm in the summer, so I'm kind of wondering should I try 10w30; benefits vs. risks? Could you expand on your first two paragraphs. Thanks.
Sean
#20
I experienced something very similar. I changed the oil recently in the '94 E36. I had been using Mobil 1 10w-40; I put 5w-30 in it, thinking that would be better for the winter weather in this area. No noise until the engine got nice and warm on a recent day when the temperature hit 70 degrees. At idle there was a tap-tap-tap noise coming from the engine. I popped the hood and determined it was coming from the VANOS bulge at the front of the engine. I could FEEL it when I put my hand on it. If I rev'd to +1500 RPM, it went away, apparently as the oil pressure/flow improved.
I checked it out on several other forums, and found a very long discussion about it. I forget where, but I did clip this because it summarizes the problem nicely.
The only clarification I can add is about his statement regarding the "stuck VANOS myth". The VANOS Solenoid can get stuck, this is commonly known, and is a $125 - $150 DIY repair, but the VANOS assembly getting stuck is apparently rare or not possible.
He also says to go 15w-50. I would go to 10w-40 first, 15w-50 is pretty darn thick, it could cause other issues such as poor lubrication at tight tolerance areas (cam and crank bearings), especially on newer and low mileage cars.
Many people do not realize this but vanos is COMPLETELY run on oil pressure alone. If you do not have the proper oil pressure you have no vanos. Imagine the vanos system as a dual oil path way maze. one oil pathway is for when vanos is not engauged, the 2nd is when the vanos is supposed to be engauged. the thing that shifts between the oil passages IS the vanos solenoid, thatts why it is such an essential part of vanos. without it you have no vanos. if the solenoid does not operate 100% vanos will not work properly. Lets say the vanos only has enough force to push change the machanism that changes the oil pathway 50%, well that means only 50% of oil will get into the "vanos on" pathway and thereby reducing pressure greatly which will then in turn only move change the cam timing by 6 degrees (instead of the full 12 as it is supposed to in the mid range).
Another factor that is essential is the oil ITSELF. it is the mechanism by which u push the vanos gears. If you use a really thin oil (aka mobile 1), it flows like water and it does not have the same oil pressure as a much heavier 15w-50 weight oil which is much thicker (think of molasis). the 15w-50 is able to "push" the vanos to the proper specs better b/c it has higher compression & oil pressure characteristics and is much thicker. so your oil is just a crucial aspect as the solenoid or vanos mechanism itself. Thats why you see so many people say "i replaced my vanos but the noise came back!" well duh! u are using the wrong oil or your solenoid is bad.
So basically... if you are have vanos problems here is the order you should replace things...
1) change to a much thicker oil (preferably a 5w40-20w-50, bmw recommends 20w-50 for a reason, but you can do castrol 5w-50 which will work in pretty much every weather condition & bmw recommend castrol anyways).
2) change vanos solenoid
3) then replace vanos unit if necessary (though I have spoken to NUMEROUS BMW master techs and every single one dispelled the "vanos stuck" myth. it simply cannot happen they say, jus thought i'd share that).
