Engine oil for E46 325i 2002
srl1104
23
Wyoming
#22
So will mobil1 5w-30 actually hurt your engine or damage the VANOS? I just changed the oil in mine and all I could find in my town was some mobil1 5w-30. Should I change my oil out to something heavier or is the 5w-30 ok untill my next oil change? I normally use Amsoil in all of my vehicles and I am conisering switching to the Amsoil 5w-40 European car formula.
#25
Probably not. But I'll bet if you did have engine trouble under warranty, and they knew you used 40 weight, they would deny the claim.
The manufacturers design the engines for a specific oil. In particular, the engine tolerances (mechanical gaps) are much smaller and more consistent than 15 - 30 years ago, due to advances in machining techniques. Since the engine is "tighter" the thinner oil flows easier and lubricates better. That's why 5w-30 is most prevalent now, where it used to be 10w-40 years ago. So going with the recommended oil is generally a good idea. Remember that the second number (30, 40, 50) is the weight or thickness of the oil. The first number is only cold temperature rating.
I would not run 5w-50 in any "modern" engine that calls for 5w-30, it's probably a bad thing.
