Xyrium said:
Is the head unit that comes with the factory stereo the same as the HK system?
Tks,
Paul
If I recall correctly it is the same basic head unit with some slight differencews because of the DSP. That said it is still very, very possible to install the high/low filter adapter on either system from the high level output on one of the rear deck speakers. The wires run right under the backrest portion of the drivers side rear passenger seats and are relatively easily accesible.
In response to the other question: No I do not know anyone who has replace a HK with a JL system. IMHO opinion spending all that extra money is NOT neccesary unless you are thinking about entering your car into a competition. Remember by adding a sub the way I described above you keep all the funtionality of your stock dsp. The main prob with the bmw system is "lack of bass". With a sub installed you can tone down the bass levels on the stock HK system therefore leaving more resources in the stock system for your highs and mids.
I am not a stereo guru but I do love my sounds and like a little "hump" in my trunk
![Thumbs Up [thumb] [thumb]](/images/smilies/icon_smile_thumb.gif)
I did a WHOLE lot of research before I finally decided to leave my system stock and just add the sub.
Check this out:
http://www.bmwtips.com/tipsntricks/DSPStereoarchive/DSPstereo.htm
