bmwrocks said:
I was thinking about the electronic throttle controls on our cars. There is going to be some inherent lag in the system just because of what has to happen:
1. Accelerator pedal sensor changes position when pedal moves (hardware)
2. New sensor position is processed by computer (software)
3. Resulting commands cause changes in engine management settings (hardware and software)
This process will introduce some transport delay from the initial hardware input to the resulting engine/transmission output. I don't what the spec is for this but I could see it in the range of a 125 ms to 250 ms response time as being acceptable.
Imagine the blank stare you would get from a service advisor if you started talking about this.......
I can just imagine the SA's expression
