Well we know the auxilary fan turns on so that would rule out fuses, resistor and the fan itself. There are two more things that could be a problem. One being the radiator temp switch that turns on the the fan through what could be the second problem, that being the relays. I believe there is a relay for each of the two fan speeds.
Honestly i would replace the switch that screws into the radiator first.. number 5 in this picture:
http://www.realoem.com/bmw/showparts.do?model=CB33&mospid=47498&btnr=17_0093&hg=17&fg=05
Hopefully that would work out for you. at least as far as making the aux fan work.
If it strats working and you still run hot, you would want to check out your mechanical fan clutch. THe fan attached to your engine.
Keep us updated so we can all learn from this. (me included!)
and good luck
and good luck
